Author: Subject: GearBox?
LoCostLancs
posted on 8/5/03 at 09:09 AM Reply With Quote
GearBox?
Can I get a Sierra 5spd Close ratio box to fit my 1300 xflow engine?.
Or will I have to get a ecsort boring 4speed box?
theconrodkid
posted on 8/5/03 at 04:43 PM Reply With Quote
type 9 fits straight on,dunno about mt75 but knowing ford it will
who cares who wins
pass the pork pies
david walker
posted on 8/5/03 at 06:10 PM Reply With Quote
What's more boring - 1300 X'Flow or 4 speed box?
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
LoCostLancs
posted on 8/5/03 at 08:01 PM Reply With Quote
Thanks Conrodkid!!
Where not all rich Mr Walker, thanks for the non-helpful info
[Edited on 8/5/03 by LoCostLancs]
Mr G
posted on 8/5/03 at 08:08 PM Reply With Quote
As long as you use a clutch with the correct amount of splines you can mate any type9 box really. Problem being that using a 1.6 7.5" 23 splined clutched with a 1.6 5 speed type 9 you aint gonna get close ratios.
Quick table
The ford boxes that as standard had close ratios were the 2.8 v6 ones if i remember (as used by caterham)
Problem with the v6 boxes = longer input shafts.....
Solution would be a 2.0 clutch with a second hand 2.0 type 9 containing a close ratio kit from a rally spares place.
Hope that might help
G
[Edited on 8/5/03 by Mr G]
david walker
posted on 8/5/03 at 09:43 PM Reply With Quote
Where not all rich Mr Walker, thanks for the non-helpful info;
You must be rich if you are planning to use a proper close ratio 5 speed box! For slick gearchanges the 4 speed is better any day - have you driven cars with both types? - I have.
And by the way - LIGHTEN UP!
Mr G
posted on 9/5/03 at 08:08 AM Reply With Quote
The 4 speed RS2000 box I had was a pleasure to use.
