Scooby
| posted on 9/8/06 at 06:04 PM |
Modifying Rover v8 5-speeder
Hi Guys,
A slightly strange question I know but..........
Has anyone modified an SD1 gear-box extension housing so it moves the gear-stick forward (towards the front of the car) and not backward as
normal???
If it can be/has been done can anyone supply details/pictures???
Paul (Notts)
| posted on 9/8/06 at 06:38 PM |
someone posted pics a while back of how they cut the extension and shortend it - or you can use the extension and gear stick from a LDV or some thing
like that because they used the same gearbox but a very short extension
Paul
Donners90
| posted on 9/8/06 at 06:45 PM |
As Paul says, the Sherpa remote is MUCH shorter than the SD1 version. Pic below is what I have in my Viento.
| posted on 9/8/06 at 08:02 PM |
Some manual Jaguars had an extension that is between the LDV and the SDI in legnth. Used on Marcos Mantula. Think they were fitted to 2.8 XJ6 as
standard
v8kid
| posted on 10/8/06 at 07:18 AM |
Done just this inmy TR7 when I moved the engine back 13". Cut the ally extension so that the spiggot of the gearstick connected directly into
the cranked ball joint on the selector shaft.
I had to weld a ally plate on the front of the shortened extension but could not get my MIG to ally weld. Ended up using that solder stuff Frost sell
- fantastic. Been using in competition for 2 years now. looks a bit like the Sherpa one except its ally instesd of cast iron.
Go for it - not as confusing as it sounds
