posted on 25/8/06 at 07:24 PM |
Toyota Gearbox
I have RWD gearbox that came from an old Celica XT.
Is this the T50 box that I hear people using with the 4age engine? I've heard it can be used with a Chevy 5.7 small block....
rick q
posted on 25/8/06 at 09:41 PM |
if it's a T50, there's no way it would take the torque from a V8.
Even with decent internals, they become a bit frayed at 200hp.I
timmy
posted on 25/8/06 at 11:53 PM |
What engine is in the Celica?
I'm assuming that the XT is the same one we got in Oz, it will be the 20R or 22R engine.
If that's the case the g/box will most likely be a W-series steel or alloy case jobby. And they can take a decent amount of punishment.
It should have some casting marks on the bellhousing or casing that should help identify it.
posted on 26/8/06 at 11:15 AM |
The engine was an 8 valve 4 pot job, big and heavy as I recall. I've dragged the box out of the shed, no numbers or ID on any of it:
[Edited on 26/8/06 by coozer]
timmy
posted on 28/8/06 at 09:52 PM |
Looks like it's a W55/57/58 gearbox.
See:
http://www.oz-clubbies.com/phpBB2/viewtopic.php?t=4597&highlight=&sid=786335a5401d0c4226eeb1f5302bcbf7
jolson
posted on 30/8/06 at 07:12 AM |
Definitely a W5x gearbox. In the UK, the engine was probably a 21R.
AFAIK, no practical way of fitting it to a 4AGE
John
thomas4age
posted on 30/8/06 at 09:24 AM |
If You want a 4age engine, get a T50 Box of a toyota AE86 corrolla coupe RWD, they're really light (all alloy) and plenty strong for use in a
light vehicle. some dutchies driving around with 200hp 4agze's in front. Just make sure that you have the right flywheel (212mm clutch)
otherwise the plate won't fit the input shaft splines on the T50 box.
and if something bigger is used engine wise you can best take the W58 box, though they don't come cheap, the're very very strong.
I recall talking to a supra owner who had a 2JZgte engine in front off it splattered with Blitz parts doing something like 700+hp on the stock box. We
came talking after he did a spendid take over on the main straight at the Zandvoort Race track in holland, I was doing 170+ half way down, and he
passed me like I was at standstill.... scary fast! also the cobra boys use them for Twin Turbo'd 1uzfe toyota V8 engine's up to 800hp .
either a BW T5 or a W58 is in order for super serious power.
The Box shown in the piccie is the W55 one which you can also find in the Nissan 200SX 1.8 turbo (CA18DET engine) ie strong and cheap'ish
grtz Thomas
[Edited on 30/8/06 by thomas4age]
If Lucas made guns, Wars wouldn't start either.
posted on 11/9/06 at 07:56 PM |
Thinking about a diesel engine and was wondering which Toyta diesel engien attaches to the W gearbox I have?
Any different bell housings to suit large diesels??
