bootneck
| posted on 2/9/06 at 10:40 AM |
ford 1800 cvh need help
hi new to all this. i have a 1800 ford cvh engine in my mk locost. its reasonable but i would like to know if i can get more out of the engine or am i
wasting my time. not many people seem to want to touch them. also how hard is it to put another engine in if mine is no good. i was thinking a rover
VVC OR K series from ebay i know this has probably been disgust before but like i said im new to this so please excuse me. any help would be most
gratful.
cct7kitcars
| posted on 2/9/06 at 10:45 AM |
if you have the room in your engine bay you can put nearly any engine in you want
joe
cct7kitcars
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in
sideways, Chardonnay in one hand, Tequila in the other, body bearing battle scars and totally worn out, screaming- WOO HOO!! What a Ride!
bootneck
| posted on 2/9/06 at 10:49 AM |
theengine bay is big the car is up and running i just feel i might have got the wrong engine. if i do put a new engine in do i have to change the gear
box or can they be linked
cct7kitcars
| posted on 2/9/06 at 10:51 AM |
what gearbox you got fitted
whitestu
| posted on 2/9/06 at 11:25 AM |
A Zetec would be fairly easy.
bootneck
| posted on 2/9/06 at 11:33 AM |
from a 1988 serria. 5 speed box
bootneck
| posted on 2/9/06 at 11:36 AM |
whitestu is your 1800 standard or have you played with it. do you know what bhp yours is running at
andyharding
| posted on 2/9/06 at 11:47 AM |
I gas flowed a 1800CVH head and increased the CR to 10.5:1 for a mates Sierra.
He was well chuffed with the result - it went faster and was more economic when not standing on the loud pedal.
I *think* it would be possible to fit a cam from something with a sporty 1600CVH to get even more poke.
Coupled with bike carbs there would be a huge difference in power.
cct7kitcars
| posted on 2/9/06 at 11:48 AM |
it all depends on how much money you want to spend
mookaloid
| posted on 2/9/06 at 12:05 PM |
Turbo?
whitestu
| posted on 2/9/06 at 01:31 PM |
Mine is totally standard - I haven't done my SVA yet to I don't know how quick it will be.
I had an email discussion with a guy from Ferriday engineering [they do a lot with CVHs] who reckoned bike carbs and a slightly raised CR would give
around 120 BHP.
He also said that he didn't think it was worth spending much on the CVH head as it would never be great.
I had originally planned to do stuff with the CVH, but my plan now is to fit a 1.8 Zetec with bike carbs at a later stage as the engine is more
powerful, smoother, stronger and a bit nicer to look at.
The Zetec will be a fairly easy swap for the CVH, the only complicated thing being the ignition, for which I'll use a Megajolt.
Stu
ps the guy from Ferriday said a turbo installation on the CVH would be easy - the 1.6 head on the 1.8 block gives a suitable CR for a turbo so this
could be a cheap way to lots of power.
Personally I prefer normally aspirated engines so didn't fancy this route for myself.
[Edited on 2/9/06 by whitestu]
Surrey Dave
| posted on 2/9/06 at 01:55 PM |
Mine has gas flowed head , 1mm skimmed off , Megajolt ignition + bike carbs ( as i told AndyHarding) .
Goes quite well ,and did not embarrass itself at a Brands Hatch trackday with Elises ,Vx220's etc
You can,t use any other UK cvh cams ,the journals are a different size.
You can replace the pistons and then use all the 1600cvh tuning option together with the head.
You may be able to get a cam from the USA that will fit as the 1800cvh is based on the American cvh.
Mike Tanski at Ferriday Engineering does lots of stuff for CVH.
As the head is quite badly flowing Turbo could be an option but you would have to drop the compression.
Surrey Dave self appointed 1800cvh pioneer!!!!
[Edited on 2/9/06 by Surrey Dave]
bootneck
| posted on 2/9/06 at 02:37 PM |
thanks for all this it sounds more promising. if i get all the parts from brakers and ebay are their garages out their that would put in in and set it
up. i dont want to spend mega bucks fut a little project over the winter is ok. the other idea was to put a rover 1.8 turbo k series in.
bootneck
| posted on 2/9/06 at 02:49 PM |
looks like you have twins on their what manifold have you used and can i just get any carbs to put on their
Surrey Dave
| posted on 2/9/06 at 03:31 PM |
My carbs are Suzuki gsxr750wn 38mm, I made the manifold from mild steel.
bootneck
| posted on 2/9/06 at 04:18 PM |
looks impresive thanks for that. could you be perswaded to make another for a standard 1800? cheaky i know!
Surrey Dave
| posted on 2/9/06 at 05:14 PM |
Sorry no, it took quite a bit of faffing about , and a bit of help from Mr Fozzie ( aka DLT)
| posted on 2/9/06 at 09:57 PM |
Hi Bootneck, welcome.
To answer your question to replace your cvh engine there are some easy options.
Taking it easy for you a 2.0 Pinto would be a straight forward swap but for some real hikes go for a Zetec. The 1.8 is easiest and can be made to give
the same power as a 2.0 with cams etc.
Getting in a bit further would see some bike carbs, Bogg Brothers can sort you out for a manifold, running a megajolt ignition system.
As Surrey dave above I made my own manifold from steel with a drill and jig saw.
You can find all the answers to your questions here. The guys have a wealth of advise, experience and knowledge.
bootneck
| posted on 3/9/06 at 04:00 PM |
thanks for all your help guys will let you know how its turned out.
