Author: Subject: Engine height??
Danozeman
posted on 15/5/03 at 05:48 PM Reply With Quote
Engine height??
Could some one please tell me the height and width etc of the x-flow and pinto engines??
How much higher is the engine than the top chassis rail??
david walker
posted on 15/5/03 at 06:03 PM Reply With Quote
I did a post on this on 7th April - measured up a few engine heights.
From c/line of crank to top of rocker cover, X'Flow is 15", Pinto is 17".
Didn't measure widths, not really a big deal on OHV or SOHC 4 cylinder engines.
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
Danozeman
posted on 16/5/03 at 01:59 PM Reply With Quote
Thanks mate. Your car looks nice btw.
How much of the sump hangs below if any?
What about the RV8?
david walker
posted on 17/5/03 at 11:52 AM Reply With Quote
Thanks, but it probably looks better in the pic than in real life!
I had/have a problem with engine height, even with a X'Flow.
When I built my car there was no Locostbuilders forum and I was pretty much on my own, therefore followed the "Book".
My sump sits an inch below the bottom rails as per the book. It's not chopped but could have been. As I have used an RS2000 gearbox, and these are bigger than the smaller X'Flow boxes - in the bell housing area - I could have only chopped an inch off the sump anyway. After that the bottom of the bellhousing is in the way.
Consequently my engine sits a little on the high side. If I were to build another.........
I'll take the tape measure to a RV8, however the issue with one of those will be - what type of carb system are you going to use? After that I would have thought that width, as well as height, becomes the proble.
Danozeman
posted on 17/5/03 at 01:36 PM Reply With Quote
The width etc isnt a prob. Im using an American small block for V8 and just wondered how high other engines were cos mine is a tad on the tall side.
steve m
posted on 17/5/03 at 09:17 PM Reply With Quote
I am glad someone else built a book from the book without this forum (just like me)
my x flow hangs out the bottom about 2 inchs from the bottom rail and is only 3 inches from ground level, and in 4 years of motoring I have not had any problems
with grounding, speed bumps etc
