bob
| posted on 19/9/06 at 11:05 AM |
type 9 input shaft movement ?
After removing the pinto today i noticed a fair amount of play in the input shaft,i cant recall as much or any play when it went in nearly 4 years ago
and wondered how much play is acceptable if any.
The movement is in out and sideways.
flak monkey
| posted on 19/9/06 at 11:30 AM |
They all have quite a bit as they are on a self aligning/floating bearing
Sera
http://www.motosera.com
bob
| posted on 19/9/06 at 11:43 AM |
Thanks david
I'm starting to cheer up a bit now.
NS Dev
| posted on 19/9/06 at 11:51 AM |
They are not actually on a self aligning bearing at all, but still don't worry about a fair bit of play. The spigot bearing holds the shaft
steady when the box is fitted.
bob
| posted on 19/9/06 at 12:21 PM |
Cheers nat
I had a look through my notes from the 1st install and found i had found this before,my memory is crap and i'm glad i kept a build diary.
thanks again
Danozeman
| posted on 19/9/06 at 06:23 PM |
MInes go loads of movement. As Nat said. when its in the spigot brg it wont move.
Dan
