Author: Subject: Question on X Flow Water pump pully
Fifer
posted on 20/5/03 at 06:50 AM Reply With Quote
My new X Flow water pump has (as normal) four bolt mount for pully. Problem is, the threads and centre hub are different than the two pully's I have ? They both have larger bolt holes and a larger centre hole ?
I have a pump that I got from Chris but it is different from the one fitted on the engine ??
Anyone know where to get a pully to fir this pump ?
timf
posted on 20/5/03 at 08:23 AM Reply With Quote
pully
Get one from burtons. the standard ones are stamped steel and have a tendancy to fly apart. having seen it hapen on a mk2 rally car and the hole in the steel bonnet !!
Fifer
posted on 20/5/03 at 09:40 AM Reply With Quote
I think thats the Crank pully you are refering to, i have a steel crank pully, this is the water pump pully that is giving the grief.
Thanks anyway
Gizmo
posted on 20/5/03 at 03:13 PM Reply With Quote
Can you accurately measure the diameter of the centre hole that you require and I'll see if I have one.
---john---
locost7-online.com
posted on 31/5/03 at 04:38 PM Reply With Quote
has the centre spigot on the pump got threads on it? it could be one for use with a viscous fan coupling, you can get a different pump i think.
the bolts have changed to m8 metric from unc from memory on new aftermarket pumps.
john
Locost Xflow 150bhp injected! Sold :-(
Facebook blog https://www.facebook.com/Johns-Tiger-Avon-Build-814223212056368/
PLEASE NOTE THIS MEMBER IS NOT A TRADER.
Fifer
posted on 2/6/03 at 12:23 PM Reply With Quote
thanks for the response. Pully I have but doesnt fit is 23mm internal dai.
Pully shaft on new water pump I have is 20mm dia.
The existing pully when mated up to the water pump hits the pump body aslo so is effectivly too deep
Any assitance appreciated
My tel is 07899066623
posted on 2/6/03 at 12:37 PM Reply With Quote
Is it one from a fiesta engine, the newer HCS or valencia? worth a look in the scrapyard for one.
yours, Pete.
david walker
posted on 2/6/03 at 08:56 PM Reply With Quote
Sorry, but why don't you go to your local motor factors and ask for the proper pump?
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
Fifer
posted on 3/6/03 at 06:57 AM Reply With Quote
Very good !
I am assuming that this pump is an updated version of the origional and it would be nice to get the correct pully for it.
Only asking if some of the more knowledgable out there could help !
