Iain Campbell
posted on 20/5/03 at 03:52 PM |
Starter help
I've a 1300 x/flow, light weight flywheel, 1300 sport 4 speed box, I want to fit a pre-engaged starter, I've tried a sierra one, it fits
the hole but not long enough to reach the flywheel, I've tried another from a front wheel drive 1600 escort, but far to small, help needed to
know what starter to fit....
Hornet
posted on 20/5/03 at 04:10 PM |
Not sure if I'm talking crap..... the flywheel is designed for specific starter. i.e. parallel teeth for pre-engaged and a lead in for the
inertia starter.
There is also a different number of teeth involved.
So... as i write i am thinking.. perhaps you can interchange..... and then perhaps you cant.... I have both types of starters in my garage, i will
measure both for you if that helps?
Cheers...
Iain Campbell
posted on 20/5/03 at 05:23 PM |
Starter help
Many thanks,
