Author: Subject: CVH
liftarn
posted on 22/5/03 at 10:29 AM Reply With Quote
CVH
Does anybody have experince with using the CVH from a MK5/Mk6 Escort?
At http://www.sylva.co.uk/cvh.html there are some issues listed. "The CVH does not have an engine mount on the near-side." and "The standard CVH clutch pack is not suitable for in-line operation.".
timf
posted on 22/5/03 at 10:31 AM Reply With Quote
rwd cvh
ford actually produced this
in the 1800 sierra's , this would give you all you need to go !
liftarn
posted on 22/5/03 at 10:40 AM Reply With Quote
CVH from Sierra
The problem is that it doesn't fullfill the emissions requirements (see the thread "Clean engine" so that's why I need the engine from a newer car.
timf
posted on 22/5/03 at 11:04 AM Reply With Quote
now confused
if you want a cvh from mk4/5 they will be the same age as the sierra cvh so how can one be clean and the other dirty ??
liftarn
posted on 22/5/03 at 11:22 AM Reply With Quote
Also confused
Good question. Perhaps the engines was made in different configurations since the Sierra is a larger car than the Escort. Perhaps it's just that I misunderstood something.
The requirements are lambda probe, coal canniser and cat.
timf
posted on 22/5/03 at 11:31 AM Reply With Quote
nat a cvh then
The cvh was not fitted with such things as it was replaced by the zetec designed for emmisions in mind.
liftarn
posted on 22/5/03 at 12:07 PM Reply With Quote
No CVH Sierra in Sweden
Ok, I got a reply at the swedish Locost forum and the Sierra was never sold with CVH in Sweden.
So it looks like the best choise is either the tuned down Pinto from the 1988-89 Sierra or just take the 7000 SEK penalty fee.
ned
posted on 22/5/03 at 12:08 PM Reply With Quote
how much is 7000SEK in british money?
beware, I've got yellow skin
kingr
posted on 22/5/03 at 12:20 PM Reply With Quote
£450 odd I believe. Personally, I think I'd be tempted to go the zetec route. At least that £450 will be going towards you rather just straight into the tax man's pocket. Second hand throttle bodies crop up on ebay and the likeness, you could presumably use a megasquirt for the ecu... you get the picture.
Kingr
liftarn
posted on 22/5/03 at 12:50 PM Reply With Quote
About £450. Perhaps not that much, but since a local scrapper charges 1500 SEK (about 100 GBP) for any engine regardless of donor it feels like it's a cost that could be avoided.
ned
posted on 22/5/03 at 01:08 PM Reply With Quote
I agree with kingr, rather than throw the money away, invest it in a better engine.
Andrew.
liftarn
posted on 22/5/03 at 01:38 PM Reply With Quote
Since my strongest candidate is the MK Indy the easiest would probably be to use a Pinto from the 1988-89 Sierra.
Since I'm not very experienced in auto mechanics I think it would probably be best to not try something untested.
PeetBee
posted on 22/5/03 at 04:06 PM Reply With Quote
Originally posted by liftarn
[About £450. Perhaps not that much, but since a local scrapper charges 1500 SEK (about 100 GBP) for any engine regardless of donor it feels like it's a cost that could be avoided.
This may be a silly question but if you are looking to build a MK Indy then wouldn't buying a complete sierra (with pinto) give you all the parts you need to build the car?
Also you may be able to buy a rusted out sierra for the 1500SEK that the scrappy would charge you for the engine by itself. (possibly!)
liftarn
posted on 23/5/03 at 07:41 AM Reply With Quote
The problem is that the engine is in 89-90 Sierras and they aren't quite rusted out yet and 15000 SEK seems to be the general price level. So a rusted out, older Sierra with a newer engine may work.
