paulf
posted on 22/5/03 at 08:05 PM |
Manifold length for twin 40s
I have been offered a manifold to fit webers to a crossflow.I am told it is a short version which is what is required to fit a seven type car.Can
anyone who has one fitted tell me the actual length required so as i can measure it before buying it.
I know this has been discussed recently but cant find the actual size required.
Paul.
Viper
posted on 22/5/03 at 09:29 PM |
the shorter the manifold the higher the torque the longer the manifold the higher the revs....
Stu16v
posted on 22/5/03 at 10:24 PM |
Wrong way round m8
The THEORY behind tuned lengths is that the longer the inlet tract (i.e manifold, intake trumpets etc) the torque the engine will pick up at lower
revs, but at the expense of power at the top end of the range. But in practise, very often it turns out to be b*ll*x anyway, changes in inlet AND
exhaust lengths depend on the whole package of engine tune. The only way to find out is experimentation on a rolling road/dyno.
Paul, are you talking about power, or merely trying to get a manifold that fits? IIRC Scutter has had similar troubles recently, I beleive that
depending on how engine sits in relation to chassis, a manifold with a slight 'swan neck' may be required.
HTH Stu.
kingr
posted on 23/5/03 at 08:19 AM |
Yup, seconded, longer manifold = greater volume of air = greater mass of air = greater inertia (given that it's travelling at the same speed as
it would with a shorter manifold) which means more air/fuel mix is forced into the cylinder (or not blown back out as the case may be) at lower
RPMS.
Kingr
posted on 23/5/03 at 08:50 AM |
I think he just wants it to fit under the bonnet.
yours, Pete.
kingr
posted on 23/5/03 at 09:05 AM |
Short as possible probably then!
Kingr
paulf
posted on 23/5/03 at 08:19 PM |
Thats correct I have been told it is a straight manifold without swan neck and about 3 inches between faces, will this fit a book dimension car when
fitted with twin dellortos and air filters?.I wanted to know before I pay for it as I wont be trying it on the car for a while as it is presently set
up with a downdraught carb.
yours, Pete.
Viper
posted on 25/5/03 at 06:34 PM |
Wrong way round m8
HTH Stu.
yep your right............must put my cock up to either to drunk or to tired...
