Shamrock GS
| posted on 13/10/06 at 08:11 PM |
Pinto plumbing
I have a 2l pinto with twin 40 webbers (given by a friend) in my locost. At the point now of connecting everything up and have got stuck with the
plumbing. Can anyone help me with what connects where? Principally:
1. How do I connect the heater into the system? I think the connection comes off the thermostat but have no idea where it returns.
2. Where does the expansion tank fit into the system and what level should it be at?
3. What's the best way to fit a sensor for an electric fan?
Any help gratefully received
Gary
jacko
| posted on 13/10/06 at 08:18 PM |
Hi have you done a search this subject it comes up a lot on pintos
Jacko
flak monkey
| posted on 13/10/06 at 08:33 PM |
Here's one I did earlier...
Theres lots of ways of connecting them up to acheive the same thing though...
Sera
http://www.motosera.com
Shamrock GS
| posted on 13/10/06 at 08:35 PM |
Thanks Jacko
Seems there are a variety of differtent ways to do it. I think what I really need is some kind of flow chart to understand what direction everything
should be flowing, that way I can fit my bits in the correct and logical place.
Gary
Shamrock GS
| posted on 13/10/06 at 08:37 PM |
David - this is really helpful.
The overflow from the radiator - is this the same as the small pipe that exits where the pressure cap fits?
Also where would you fit a heater into this system?
Gary
flak monkey
| posted on 13/10/06 at 08:42 PM |
Heater goes onto the normal head pipe and the one from the water pump IIRC.
The overflow/expansion pipe is the one near the rad cap yes.
If you have a rad with a cap on you dont need a header tank.
Sera
Shamrock GS
Just had a look and my thermostat only has the outlet to the radiator not the second on your drawing. In this case where should the take off for the
expansion tank come from?
Gary
flak monkey
| posted on 13/10/06 at 08:48 PM |
Just from the rad is fine for the expansion hose
Sera
Dusty
| posted on 14/10/06 at 02:04 AM |
I wouldn't bother with a pressurised header tank. A simple overflow with siphon back works fine. Block the bleed from the thermostat housing.
Ford used to do a blocked hose to fit on this. Threeway bypass tap for heater for the summer.
[Edited on 14/10/06 by Dusty]
| posted on 14/10/06 at 08:46 AM |
Mine was like that but I eventually did fit a header tank in the loop to the inlet manifold as it got boring removing the nosecone to top up.
Shamrock GS
| posted on 15/10/06 at 08:59 AM |
Thanks all
I think I actually know what to do - something of a first on this build!
Gary
