Author: Subject: Anyone with a lathe & some nylon
pajsh
posted on 15/10/06 at 08:45 PM Reply With Quote
It there anyone with a lathe can make me this in nylon for beer tokens.
Its a converter to drive a mondeo TPS on a weber carb set-up.
TPS Bush
TPS Bush
U2U if you can help. Ta
I used to be apathetic but now I just don't care.
rayward
posted on 15/10/06 at 08:48 PM Reply With Quote
will see what i can knock up at work tonight for you.
Ray
Mal
posted on 15/10/06 at 09:55 PM Reply With Quote
Thread Size
If the M6 tapped hole is to screw onto the spindle of DCOE's check the thread
size. I think you will find it is M7.
Mal
pajsh
posted on 16/10/06 at 12:23 PM Reply With Quote
Thanks for thinking but it's not for DCOE.
At the moment I'm just converting a stardard 1.6 DFTH with the Sierra actuator type arrangement.
I've put an M6 thread on the end of the rod that works the carb and the bush is going through the original hole in the side if the mounting plate.
Dellorto's will be on next year when I swap the engine for the 2.0 I'm rebuilding, but I will have to get another made for them.
