kj
| posted on 22/10/06 at 04:59 PM |
Pinto engine position
I have a book chassis and a 1.6 pinto engine i will be making mounts using 50x50 box section and land rover rubbers.
what is the best position for the mounts and do they have to be of equal length? any diagrams size's or pictures would be a grate help.
flak monkey
| posted on 22/10/06 at 05:02 PM |
Heres where my engine sits with standard GTS pinto mounts.
The chopped sump/bellhousing is 1" below the bottom of the chassis.
The release arm housing clears the drivers bulkhead by about 20mm.
I have seen engines further back than this, and further forward. You really do need to check that the cam pulley isnt going to stick out of the nose
cone though! Mine is only about 5mm clear inside....
Sera
http://www.motosera.com
meany
| posted on 22/10/06 at 06:08 PM |
i have put mine further back.
using MK mounts.
The Baron
| posted on 22/10/06 at 08:27 PM |
From the back of my bell housing to the start of the transmission tunnel is 25mm
My only word of warning is that if you don’t mount the engine high enough in the engine bay, any twin dcoe's will foul on the top chassis rail
when you put air filters on.
There is a picture in my archive which shows how my air filters exit.
Hope this helps....
The Baron
kj
posted on 23/10/06 at 08:33 AM |
Thanks, i'll be back in the garage within the next couple of days.
kj::
| posted on 23/10/06 at 09:37 AM |
Mine's well back in the chassis and the sump is unmodified but causes no problems and there are plenty of speedbumps round here to test it on.
Mine's a book chassis built at home.
  Engine position
[Edited on 23/10/06 by Peteff]
kj
| posted on 23/10/06 at 05:29 PM |
Pete, do you have any pics of your mounts or sizes.How far does the sump hang down just thought it would have to be shortened.
kj:
kj
| posted on 25/10/06 at 04:10 PM |
engine position
Mounts made painted and engine going in tomorrow
