iscmatt
posted on 11/11/06 at 02:15 PM |
Starter motor
Another problem! I cant get it to start! The starter motor turns but doesnt appear to engage the flywheel. I have tested it is working by taking it
out and having a look, everything is fine. My thinking is perhaps i have the wrong starter motor. i have a type 9 gear box and pinto 2.0 engine. Can
anybody tell from the pictures if this is the right starter motor? it is p[ossible that the the starter motor came from an MT75 gearbox (are they
different?)
Please help!! i want to get my 7 going!
iscmatt
Another one
nitram38
posted on 11/11/06 at 02:16 PM |
Have you checked the solenoid on the side of the starter?
It throws the cog outwards when you turn the starter over.
iscmatt
posted on 11/11/06 at 02:17 PM |
yes it works, the cog jumps out and whizzes round, but doesnt hit the flywheel
TangoMan
posted on 11/11/06 at 03:08 PM |
It looks like you may have the wrong starter. Do you know what it came off.
I believe that the starter off the 1.8 Sierra is different. I think it may have a shorter throw.
I will be taking mine out in a couple of weeks as I start the engine swap. I can post a photo then of measurements but hopefully someone can provide a
picture sooner..
For now I would suggest removing the startere and connecting it with a couple of jump leads just to ensure that when it spins it is also being throw
out by the yoke.
Summer's here!!!!
TangoMan
posted on 11/11/06 at 05:35 PM |
Might be a deal to be done there then as I will shortly need one for a CVH. I have one lined up but a spare is always good.
I will have the one off my Pinto available in a couple of weeks.
Summer's here!!!!
iscmatt
posted on 12/11/06 at 11:03 AM |
thats great a swap would be ideal! i live just 10 miles east of york. send me an email when you would are ready to do a swap.
anthonywells17@hotmail.com
in reply to your previous post it all works, i connected it with leads etc and it jumps and spins so it is in working order!
iscmatt
posted on 14/11/06 at 11:25 AM |
is your pinto 2 litre?
TangoMan
posted on 14/11/06 at 06:42 PM |
Yep.. 2.0
I will drop you a U2U when I have removed it.
Summer's here!!!!
iscmatt
posted on 15/11/06 at 05:30 PM |
ok, cheers! look forward to hearing from you!
jacko
posted on 15/11/06 at 08:22 PM |
The starter that fits a dohc engine fitted to a mt75 box can have the nose removed and fitted to a starter that comes of a pinto engine to type9 box
. this what i had to do to get it to work Jacko
ps were do you live near York?
[Edited on 15/11/06 by jacko]
posted on 15/11/06 at 10:42 PM |
Here's the starter off my donor which had a Pinto and type 9 in it. Pinion looks in a different position.
iscmatt
posted on 16/11/06 at 01:47 AM |
Thats what this starter motor is from i think, a 2.0dohc with mt75 box. live half way between york and malton
it looks like the starter from that pinto has an extra 1/2" throwon the pinion which would explain the lack of engage when starting
[Edited on 16/11/06 by iscmatt]
