The Baron
| posted on 15/11/06 at 05:02 PM |
Dumb Carb Question.
For a ford pinto carburettor (vv) with standard mechanical fuel pump. Do I need a return fuel line to the fuel tank?
I forgot to check all those years ago when I stripped my donor.
Cheers in advance.
The Baron
JackNco
| posted on 15/11/06 at 05:09 PM |
i THINK i remember seeing in a race car is born that he said a return line is only for injection as he was using carbs, but im sure some one with some
actual experience would be more certain
John
Some people are worried about the difference between right and wrong. I'm worried about the difference between wrong and fun.
O'Rourke, P.J. (1989), Holidays in hell. London (Picador)
| posted on 15/11/06 at 05:27 PM |
I haven't got a fuel return and I'm having flooding problems at the moment. I don't know if this is down to carb set-up or not yet
though.
When I asked the question, some people were running fine without a fuel return and others had added a fuel return, so it's not really clear to
me whetehr it's needed or not. I hope not, because I don't want to have to pull the car apart to put one in
Macbeast
| posted on 15/11/06 at 05:31 PM |
My 1.6 Pinto Sierra has a return, but it comes from the fuel vapour separator and I guess goes back to the tank.
I think I've seen someone on here say the vapour separator is not really necessary on a seven type car, so the return wouldn't be
necessary.
Surrey Dave
| posted on 15/11/06 at 05:37 PM |
Regulator?
If you have flooding probs after leaving the return off you could fit a fuel regulator
| posted on 15/11/06 at 06:16 PM |
That's probably the next move to fit an adjustable one and play around with the pressure.
MkIndy7
| posted on 15/11/06 at 06:32 PM |
If your early in your build then fit one,
From our experience of atleast 3 Pinto Engined cars at our group that its required or certainly better to have.
Also should you invest in bigger carbs or Fuel injection where a regulator is involved then you will require a return, and it'll be a hell of
alot harder to fit it one when the cars all finished!.
piddy
| posted on 15/11/06 at 06:36 PM |
I had a webber 32/36 carb on my last kit.
It was brought new and had a return outlet, but I had no return pipe. The kit came with a T connection that fitted in line into the feed pipe and then
to the return on the carb,so any fuel leaving the carb from the return was taken up with the fuel being feed.
I hope this make sense.
MkIndy7
| posted on 15/11/06 at 07:08 PM |
Is there different types of return then?
I thought there was only the vapour separator canister type, that was mounted on the wing of the donor. Never heard of one where it just returns
straight from the carb.
With the Vapour seperator type we've had:
No seperator fitted and no return - Excessive Fuel consumption (when retro fitted consumption improved)
Seporator fitted and the return tee'd into the pre-pump feed line - Car wouldn't start or run until this link was shut.
Our vapour seperator will in the space of starting the car and reversing it back into the garage fill about a 1L container with petrol, so it
obviously does something!.
This has been covered many times on here with very differing answers some people say the short return works, others don't.
Think I've argued my corner lol... and on a finishing note: if it wasn't required why did Ford spend the extra money designing and fitting
one.
| posted on 15/11/06 at 07:27 PM |
I had to fit one as the mechanical pump beat the float valve and flooded constantly. I made a return from copper brake pipe to the neck of the tank
and when the engine is running there is a constant stream of petrol back to the tank.
  Fabricated engine mount
