| posted on 29/11/06 at 04:07 PM |
xflow-bellhousing spacer plate
I'm fitting an RS2000 type alloy bellhousing to my xflow, and I presume there should be some kind of plate between the engine and bellhousing to
cover up the gaps.
I started making one out a bit of 16 gauge sheet, but unsure if the plate should cover the gap at the bottom of bell housing or is this a separate
bit? Does the plate extend out and around the starter motor?
If anyone has a picture of what this bit looks like it would be very helpful!
Stuart Walker
| posted on 29/11/06 at 05:04 PM |
Yep, it covers the gap and goes around the starter motor. This is the best pic I could find, hope it helps...
Stu
| posted on 30/11/06 at 02:54 PM |
Thanks very much for that!
