spunky
posted on 30/11/06 at 11:03 AM |
Washer/dryers...
I've yet to see a question unanswered on this forum, no matter how obscure... and this is pretty obscure.
I have a washer/dryer (Candy CNW 136)
Have misplaced the destruction manual and now winter has arrived, have started using the dryer.
I can find no 'fluff filter' anywhere! Is it possible that the fluff is trapped in the condensor and pumped out? Kinda like a wet deduster
setup. Or have I just not looked in the right places.
Thanks in advance.
John
The reckless man may not live as long......
But the cautious man does not live at all.....
dave1888
| posted on 30/11/06 at 11:14 AM |
The fluff normally gets drained away with the water.
ab54666
| posted on 30/11/06 at 11:42 AM |
As washers dryers are plumbed in and have a waste pipe (rather than just an air pipe) there isn't usually a fluff filter. Some more expensive
models do have a fileter around the pump though.
spunky
| posted on 30/11/06 at 11:57 AM |
Thanks guys, i'll stop worrying about washing machines now....
How can anyone say this site isn't worth a measly 5 quid sub.
John
| posted on 30/11/06 at 01:22 PM |
The hot air coming out of the drum goes through a tube which has a cold water pipe running round it. The cold water pipe cools the walls of the tube,
condensing the water vapour in the hot air- this water then goes out the drain tube. The idea is that the drain tube takes fluff away with the
condensed water. In practice the condensor tube gets fluffed.
Whipping the back of the unit and looking for the tube usually shows fluff city. I know when I repaired my washer dryer (after 18 months!!! burnt out
dryer coil) the tube was fluffed up...
spunky
| posted on 30/11/06 at 02:17 PM |
Thanks, I'll check it after a couple of months....
