phil m
| posted on 3/12/06 at 02:33 PM |
crossflow dizzy
Does anybody have a picture of a distributor with a side exit cap fitted to a cross flow with side draughts please.
I fitted a non-vac advance dizzy prior to the carbs and ran the engine with a normal cap, but with the carbs on and the side exit cap I need to move
the dizzy to get the cap on? Also it points to the back of the engine- is this right ?
Phil
thunderace
| posted on 3/12/06 at 03:31 PM |
will this pic help
Fatgadget
| posted on 3/12/06 at 04:31 PM |
Phil
You can point a xflow dizzy any direction as long it does not foul on anything...makes no difference.
D Beddows
| posted on 3/12/06 at 04:48 PM |
To to be off topic for a second - what is that car in the picture thunderace?
phil m
| posted on 3/12/06 at 06:08 PM |
Thanks for the info
Phil
| posted on 3/12/06 at 06:22 PM |
as long as the rotor is pointing at the segment when it's supposed to be or no spark will appear
| posted on 4/12/06 at 10:57 AM |
slight off topic ; re: photo by thunderace
I see the HT leads are cable tied to gether - that is not something recommended and can cause misfiring.
leads should be far from each other and if they need to cross, they do so at right angles.
D Beddows
| posted on 4/12/06 at 11:23 AM |
But what is the car??
gazza285
| posted on 4/12/06 at 03:21 PM |
Looks like a Dutton B+.
Mr G
| posted on 5/12/06 at 01:52 AM |
That's Jorg's modified Phaeton S2
Full details
G
