Oliver Coles
posted on 5/12/06 at 08:34 PM |
Playstation 2 online help.
A couple of years back i got a ps2 network adapter kit so that i could play games on the internet. We tried then to make it work but got stuck. so
afetr two years of doing nothing we decided to have another go. This time we managed to get as far as trying to inter central station but it says it
can't make the connection. I think the problem is that we are not sure of the various requirements like ip adresses etc. Does anyone know how to
find ip, DNS, Gateway, netmask, DHCP, ppp and pppoe codes on the computer.
Any help would be much appriciated.
Thank you
Only 16 and i have already had my midlife crisis
jos
posted on 5/12/06 at 09:00 PM |
try opening dos by either start programs accessories msdos or command prompt or start run cmd
then type ipconfig and hit return
that will give you some figures to hopefully get you started
let me know how you get on
greggors84
posted on 5/12/06 at 09:01 PM |
The rest, DNS etc. You can get from your broadband provider.
Chris
The Magnificent 7!
thunderace
posted on 5/12/06 at 09:53 PM |
hi
here is sonys helpline number
08705998877
or go to this web site this will tell you your ip address
www.whatsmyip.org
once you have your ip address you need to register with sony
hope this helps
WanchaiWarrior
posted on 6/12/06 at 02:48 AM |
Easiest solution...............
Get rid of the PS2 and get an Xbox 360.
Far and away your best solution.
HTH
Jamie
