les
| posted on 12/12/06 at 05:28 PM |
zetec water temp
hi guys,
I am trying to find a location for a mechanical water temp sensor I have,
anyone know if the thermostat closes off flow to the heater pipes? Im not using a heater but thought a section of pipe plumbed in where the heater
normally goes would be a good location?
les
| posted on 12/12/06 at 05:35 PM |
If it did your heater would stop working when the stat closed.
zzr1100rick2
| posted on 12/12/06 at 05:39 PM |
A mechanical temp sensor
cant you put the sensor for your gauge in the original temp sensor port on the thermostat housing bottom one of two if i remember roght
les
| posted on 12/12/06 at 05:51 PM |
hi,
yes its a racetech type with a capilliary running to the sensor, cant put in the thermostat housing as it is too big and looks like it would foul the
thermostat,
so heater pipe could be an option.
Les
