Author: Subject: How to get a ZX9R engine and bits needed?
Gremlin
posted on 12/6/03 at 02:16 PM Reply With Quote
Does anyone know where i could get a ZX9R engine and what other parts do i need?
EZy GreMLiN
"The only way to get rid of temptation is too give in to it..!"
MK9R
posted on 13/6/03 at 06:40 AM Reply With Quote
Try to get all the bits with the engine when you buy it, otherwise it will cost you a load more.
Check you have the following, if not budget for them when deciding how much to pay:-
Engine
carbs
Full Loom (nightmare to sort out wiring otherwise, plus it has all the correct plugs/sockets on it)
CDi (£120 second hand if nbought seperatly)
rectifier (£80 second hand)
Fuel pump
Cam sensor (£20)
Relays (fuel etc)
Key and ignition barrel (not necessary but you will need to out a 100ohm resitor in the ignition wiring if use another - very simple job though)
Exhaust Can if available
Gear change arm
You don't need the airbox as it wont fit under the bonnet anyway.
give us a shout if you want anymore info
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
Gremlin
posted on 25/6/03 at 03:11 PM Reply With Quote
Thanks thats brilliant. If i go BE it will also be an indy ZX9R. If i cant afford it it will be a pinto indy.
EZy GreMLiN
Wadders
posted on 25/6/03 at 07:59 PM Reply With Quote
Met a bloke at Newark called Mike Solloway who sells bike engine packages, a member of the Dutton owners club (but we wont hold that against him!) seemed like a really genuine guy, and the prices he quoted me were super keen, also he guarantees the engines from date of installation rather than purchase.
Not sure he'd like me to post his telephone number, but if you want it drop me a u2u.
No connection BTW.
Wadders
i]Originally posted by Gremlin
