Micael
| posted on 14/12/06 at 10:31 AM |
Pullrod Clutch
I'm thinking of using a pullrod clutch set up. i have snapped my clutch cable twice this summer and i'm feed up with it.
Has anyome use this type of set up?
I konw that LSDWEB has used this, but he had his engine bolted directly to the chassie. I have rubber cushions and I suspect that my engine will move
a lot more than LSDWEB and might activate clutch.
piccy
[Edited on 14/12/06 by Micael]
Micael Moose Åman
Petrolhead and all around nice guy
"Don't leave the duck there. It's totally irresponsible. Put it on the swing, it'll have much more fun." //Sleep Talkin Man Dec 23
2009
Agriv8
| posted on 14/12/06 at 10:58 AM |
couldnt see piccy.
but assume you are after somthing like this.
pull clutch
i.e
If you are I have one of these surplus to requirements ( still boxed and un used )
U2U if you are intrested.
regards
Agriv8
Micael
| posted on 14/12/06 at 11:29 AM |
here
piccy
Micael Moose Åman
2009
macnab
| posted on 14/12/06 at 12:02 PM |
Maybe your clutch pedal is traveling to far and the clutch lever arm is bottoming out on the bell housing so your just stretching the cable. My friend
kept snapping this clutch cable on his little Fiat due to this very reason. Very fiddly to fix on it as well. Worth a check.
| posted on 14/12/06 at 12:49 PM |
Commonest reason is rigid fixing of the cable to at the pedal end so it frays and eventually breaks, or too sharp a curve in the outer making it hard
to operate. Make it like a manufacturer's original and it should last longer
Micael
| posted on 14/12/06 at 02:37 PM |
I had a too sharp curve on the cable. The cable snapped on the same spot both times and it was ju where the sharp bend was.
I have been looking to use an Saab slave cylinder and a wilwood measter cylinder. But i think it is too expensive and unnecessary complicated.
The pullrod setup seems to be easy and smart solution.
Micael Moose Åman
2009
lsdweb
| posted on 15/12/06 at 08:30 PM |
Hi Micael
As I said in my U2U, I'd expect the clutch pedal to move not the actual clutch to operate. I'd be tempted to give it a try as it's
very easy to make if you have the skills.
It gave a great feel to the clutch pedal.
Regards
Wyn
