Author: Subject: Cooling system
roadrunner
posted on 30/12/06 at 08:53 PM Reply With Quote
Cooling system
Can anyone tell me if i would suffer more cooling problems with an unlevel rad like this. Also does anyone know what rad it is , and would i be better off with a different rad , if so which one. Cheers.
wonkey rad
wonkey rad
[Edited on 30/12/06 by roadrunner]
DavidM
posted on 30/12/06 at 08:56 PM Reply With Quote
I can't see your picture, but according to a recent article in PPC the most efficient angle for a radiator is 20 degrees from vertical.
roadrunner
posted on 30/12/06 at 09:00 PM Reply With Quote
can't get my picture up again. It's actually left to right , not front to back.
nib1980
picture for you
wonkey rad
wonkey rad
roadrunner
posted on 30/12/06 at 09:01 PM Reply With Quote
Thats the one ,cheers,
DavidM
posted on 30/12/06 at 09:07 PM Reply With Quote
Left to right shouldn't make any difference. IMO.
The radiator looks like one from a Micra.
[Edited on 30/12/06 by DavidM]
graememk
posted on 30/12/06 at 09:08 PM Reply With Quote
looks like a micra to me
Shandylegs
posted on 30/12/06 at 09:09 PM Reply With Quote
It's a Micra rad. Don't see any problems with it being slightly slanted to one side.
Thanks...
roadrunner
posted on 30/12/06 at 09:17 PM Reply With Quote
Cheers fellas.
zzr1100rick2
posted on 30/12/06 at 10:16 PM Reply With Quote
looks like the filler is lower than the top hose to me wont it get an air lock ?
James
posted on 30/12/06 at 10:49 PM Reply With Quote
I agree... if you're wanting to use the filler as a filler or bleed point then it needs to be higher than the hose.
I've just ditched my Micra rad for a Polo one.... 32mm inlets in different positions matched the Pinto much better.
James
