Author: Subject: V6 Cologne/bellhousing/Type 9 question
geoff shep
posted on 19/6/03 at 05:32 PM Reply With Quote
Will a Ford V6 (which I want) mate up to a std pinto/type 9 bellhousing (which is what I've currently got)? If not, what mods/parts are required.
Stu16v
posted on 19/6/03 at 07:18 PM Reply With Quote
Yes, IIRC all euro Ford engines have the same bellhousing bolt layout.
HOWEVER.......
The fly on the ointment is that V6 engines have a different length input shaft on their gearbox (either shorter or longer, but shorter if the brain cell is serving me correctly!) which means you will have to get a V6 box, or a spacer made the same thickness as the difference in length and bolt it between box and bellhousing.
HTH Stu.
geoff shep
posted on 19/6/03 at 08:42 PM Reply With Quote
Ta, I'll give it a go - I can get a gearbox with it but it's only a 4 speed.
stephen_gusterson
posted on 19/6/03 at 10:03 PM Reply With Quote
i am using the 2.4 cologne V6 (little bro of 2.9) and it came with a 9 as std.
I wanted to use a 2.9, but all the ones I saw at auction were friggin autos.
As these engines are brothers, I wonder if you got a type 9 from a 2.4 (they are around, but no many) or a 2.9 (are there any manuals?) that it would fit and save you a whole loada hassle with the shaft....
atb
steve
James
posted on 20/6/03 at 09:09 AM Reply With Quote
Originally posted by stephen_gusterson
<snip>
Yup! I scrapped one about 4 months ago!
James
jonti
posted on 21/6/03 at 06:40 AM Reply With Quote
Geoff
If you're interested I know whre there's a 2.9I grandad wiv a good mill ..complete car for £50 (see for sale and wanted)...its an auto box though
J.J
OFROK
Alistair Mc
posted on 23/6/03 at 08:55 AM Reply With Quote
I have 2.9 v6 with type 9 from a 2.0l the, v6 has a different bell housing and a longer input shaft on the grarbox. I used a bell housing from a busted v6 box, and had a extension made to fit on the end of the input shaft. The problem without the spacer is that the shaft will not engage the spigot bearing in the end of the crank. This allows the input shaft to move about and breaks the grarbox in about two weeks,(had this problem first in a xr4i with 2.0l box).
regards
