flak monkey
| posted on 8/1/07 at 11:49 AM |
PInto cambelt tensioner
Anyone got a pic of how the spring tensioner whatsit fits on the cambelt tensioner on the pinto?
TIA
Sera
http://www.motosera.com
cct7kitcars
| posted on 8/1/07 at 12:33 PM |
i take the spring off them
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in
sideways, Chardonnay in one hand, Tequila in the other, body bearing battle scars and totally worn out, screaming- WOO HOO!! What a Ride!
macnab
| posted on 8/1/07 at 12:49 PM |
I have no pics but I remember it rested against the spit pin in the head and I think, the other end is against the arm that the rollers fitted to.
Man it's a while since I did that job
bilbo
| posted on 8/1/07 at 01:10 PM |
Here's a zoomed in pic of an old rebuild I did. Hope it's clear enough?
  Pinto Spring
[Edited on 8/1/07 by bilbo]
Build Diary: http://bills-locost.blogspot.com/
Web Site: http://locost.atspace.com
bob
| posted on 8/1/07 at 01:15 PM |
Bilbos pic will probs sort you out,here is one from the side.
tegwin
| posted on 8/1/07 at 01:31 PM |
Hahaa...My pinto doesnt even seem to have that spring!
macnab
| posted on 8/1/07 at 01:54 PM |
You don't really need it, stupid thing never managed to set the tension correctly anyway. I just set it by being able to push the belt in by
half an inch. There's probably a more scientific way but as the valves can't normally strike the pistons if it snapped I don't
care...
NS Dev
| posted on 8/1/07 at 01:55 PM |
You don't need it, in fact, as was mentioned, they can some off and take the best with them hence some folks remove them.
You can fit it, set the tension, then remove it after.
flak monkey
| posted on 8/1/07 at 05:14 PM |
Nat, what you suggest is exactly what i am planning! I have no spring fitted to mine at the moment, and it its a complete pain to get to the bolts for
adjusting it (anyone got a good way?) my belt needs re-tensioning now and its proving a pain.
Sera
