Author: Subject: throttle cable
macspeedy
posted on 24/6/03 at 04:33 PM Reply With Quote
throttle cable
looking for a good source for throttle cable, is the stuff they use on push bikes anygood?
theconrodkid
posted on 24/6/03 at 04:48 PM Reply With Quote
if your using a pinto nas yr avatar says,the std seirra cable fits a treat,just need ball from seirra pedal welded onto mk pedal
who cares who wins
pass the pork pies
macspeedy
posted on 24/6/03 at 08:52 PM Reply With Quote
eh!
Rob Lane
posted on 25/6/03 at 09:03 AM Reply With Quote
I've used a bike stainless steel brake cable from a local cycle store. Very cheap, about 2 pounds all in plus 1 pound for a second inner in case first breaks.
Never needed 2nd as first is still OK.
just make sure you use a swivel at both ends and it has no chafing points.
Teflon lined outer sheaths are also available but cost about 5 pounds.
paulbeyer
posted on 25/6/03 at 11:41 PM Reply With Quote
Rob do you have any pictures of this setup?
7 out of 10 people suffer with hemorrhoids. Does that mean the other 3 enjoy them?
