benji106
posted on 7/2/07 at 11:49 AM |
Tintop problem - Renault Clio
my '98 reg clio has been playing up for about a month now, sometimes when i turn the key in the ignition it wont start, the lights/radio etc.
all come on as normal but the starter motor doesnt kick in at all. there is no clicking or anything, and i have to bump start it.
It seems random in its descision to start or not, usually it will go a week or so with no problems then stop working for a while, but sometimes in the
middle of a good week it wont start once, then is fine for a few more days or vice versa.
any suggestions gratefully recieved
Regards,
Ben
-Everything in excess-
macnab
posted on 7/2/07 at 11:51 AM |
starter solenoid jamming, it’ll just get worse with time
John.Taylor
posted on 7/2/07 at 11:56 AM |
Ditto
Agriv8
posted on 7/2/07 at 12:04 PM |
total long shot and very unlikley but possibly bad earth on block.
next time it does it have you tried fitting a jump lead from the block to the earth on the battery. to prove if that an issue !
or if its a sticky sealnoid a tap to the stater motor can get you out off bother
regards
Agriv8
Moorron
posted on 7/2/07 at 12:20 PM |
Dont think its any of the above if the starter is where i think it is, my other half had this problem with here 1996 one and it was the solinoid spade
connector. the starter on her car is right behind the rad so gets alot of road sludge and water on it causing the conection to corrode. Wiggle it with
someone holding the starter on and see if it starts. i just pushed it on and off a few times to clean it up and it worked.
I did show her which wire to 'wiggle' if it didnt start when i wasnt about.
good luck
Sorry about my spelling, im an engineer and only work in numbers.
benji106
posted on 7/2/07 at 05:39 PM |
hey thanks for the quick responses, think it may have been the terminal as i gave it a quick clean with some wet and dry and it seems to have solved
the problem, also gave the solenoid a good tapping just to be sure
