goodall
| posted on 7/2/07 at 07:39 PM |
Radial engined car, anyone ever built one on here?
PAUL FISHER
| posted on 7/2/07 at 07:55 PM |
Not seen one in a locost but
PAUL FISHER
| posted on 7/2/07 at 07:57 PM |
or this
mookaloid
| posted on 7/2/07 at 07:59 PM |
wow they are works of art - never mind the engineering
Confused but excited.
| posted on 7/2/07 at 08:06 PM |
Should have gone to spec savers!
goodall
| posted on 7/2/07 at 08:11 PM |
nope i mean a aircraft engines that are like those in the bikes
http://upload.wikimedia.org/wikipedia/commons/a/ab/Radial_engine.gif
MkIndy7
| posted on 7/2/07 at 09:21 PM |
I've seen a Tractor with one on....
Oh and a Supercharged V8 as well, Like a Cheery on top!
roadrunner
| posted on 7/2/07 at 09:30 PM |
NICE
steve m
| posted on 7/2/07 at 09:57 PM |
"Radial engined car, anyone ever built one on here?"
why ??
goodall
| posted on 7/2/07 at 09:59 PM |
be so smooth and powerful
rav
| posted on 7/2/07 at 11:58 PM |
It would be a hell of a sight!
I was looking at radial engines in the london science museam last weekend, there were some inventive minds around in the early days!
Was particuarly taken with the "gnome", a small early radial where the cylinders rotate around a fixed crankshaft.
The cylinders fill through the crankcase via 'flapper' valves in the pistons, exhuast gasses leaving through a single poppet valve on top
of the cyl head - straight to atmosphere.
I suspect it wouldn't be very free revving and would totally suck in a car but it was extremely cool
I suppose a small radial might fit a modified locost engine bay with the crankshaft pointing up vertically. Not sure how you'd transmit the
power to anywhere where it could be of use, but I'm sure if you really wanted to do it...
Simon
| posted on 8/2/07 at 12:02 AM |
Not necessarily
Can you imagine trying to balance a whole rotating assembly. Another thing is they don't have much in the way of throttle control, run lowish
compression etc.
I've seen a scratch built rotary and radial (amongst others) - superb to look at, but completely impractical for car use.
Simon
trogdor
| posted on 8/2/07 at 08:44 AM |
have seen a car with a radial engine, but it was a scratch built special from the 20's or 30's with an aircraft engine in it, did go about
70 tho!
not cheap engines i would of thought to get hold of
| posted on 8/2/07 at 09:29 AM |
too much hassle, imagine tring to get a spare for it inhalfords
goodall
| posted on 8/2/07 at 06:34 PM |
radial engine have a fixed crankcase rotary engine have a fix crank
mad4x4
| posted on 9/2/07 at 04:46 PM |
NOISE how would you pass the noise emmissions .
Scot's do it better in Kilts.
rav
| posted on 9/2/07 at 07:01 PM |
Isn't a rotary engine another name for the wankel engine, as used in mazda's? I was talking about a radial engine, eg cylinders radiating
from centre, where all the cyylinders rotate around a fixed crank.
A rotating radial??
goodall
| posted on 9/2/07 at 07:04 PM |
no radial is rotating crank and rotary is rotating cylinders, wankel is just wankel and is commonly known as a rotary engine but if you want to call
it a rotary engine call it a wankel rotary engine then your correct
