grahamgg
| posted on 14/2/07 at 08:51 AM |
zetec alternator
Pictured is a 1994 1.8 zetec from an escort,will this set up work when i move alternator,will water pump be running correct way,thanks
[Edited on 14/2/07 by grahamgg]
procomp
| posted on 14/2/07 at 09:04 AM |
Hi the water pump will still turn in the same direction. Most people fit thier altenators on zetecs there or there abouts.
cheers matt
Danozeman
| posted on 14/2/07 at 10:44 AM |
Itl work just fine. Thats where mine is. Being an escort silver top it will have the correct pump in.
Dihatsu charade alt will tuck down there a treat.
Dan
grahamgg
| posted on 14/2/07 at 11:22 AM |
thanks for the info
mad4x4
| posted on 14/2/07 at 12:53 PM |
Mine is at the other side where the original alt was, didn;t have space down there due to steering column.
Scot's do it better in Kilts.
stevebubs
| posted on 14/2/07 at 05:24 PM |
yes.
Ian D
| posted on 14/2/07 at 07:48 PM |
I have my alternator where you are proposing to put yours. Had some difficulty with brackets and mounting can provide picture if you want
Ian
grahamgg
| posted on 16/2/07 at 10:16 AM |
thanks ian d
