darrenga
| posted on 22/2/07 at 05:36 PM |
gear extension
anyone used these and are they ok for the mk
flak monkey
| posted on 22/2/07 at 05:40 PM |
Will fit anything with a type 9 box. Should move the stick back about 3 or 4" IIRC.
Sera
http://www.motosera.com
| posted on 22/2/07 at 05:49 PM |
Made my own following plans from David Jenkins site , moved gearlever back 5" and works a treat
greggors84
| posted on 22/2/07 at 05:53 PM |
Got one on mine!
Where is that one from? They all the look the same, but Ive heard the westfield one is better quality than the tiger one.
Chris
The Magnificent 7!
darrenga
| posted on 22/2/07 at 05:57 PM |
gts on ebay
JohnN
| posted on 22/2/07 at 06:51 PM |
who are GTS ?
Marcus
| posted on 22/2/07 at 07:22 PM |
Fortunately, they appear to be in stock at Rally Design!
Marcus
Because kits are for girls!!
John22000
| posted on 23/2/07 at 10:30 PM |
I've just had one delivered from Rally Design. Looks like a great piece of kit but I'm a little bit worried its going to be a pain in the
A*** to fit.
There is a cross member on the top of the transmission tunnel that looks like its going to get in the way.
I either need to try to drop the back end of the gearbox own by just over an inch or move the offending bit of box section....
Anyone know how structural said bit of box section is?
The choice is either cut it out and weld it back in a few inches further back...or (seen as the car is completed) cut it out and forget about
replacing it a bit further back.
Whats the general concensus of opinion on this one ?
Greggors,
You say you have one on yours, how did you manage to fit it ?
Should say.......Pinto engine bolted to the front of the gearbox.
John
dan8400
| posted on 29/6/07 at 08:35 PM |
The tiger thing is a peice of crap!! It is a rose joint with a bar through it and a spring (to press down for reverse stop) and a thead on top (for
gear knob). This is then attached to the original gearsitck (top hacked off) with two metal straps and bolted together. Heath Robinson would have
thought it crude!!!
dan8400
| posted on 29/6/07 at 08:49 PM |
Sorry forgot to mention, i bought one of the extensions above ^ (darrenga) from ebay around £60 with postage. Great unit. Works really well!!!!
minidoido
| posted on 6/1/08 at 10:07 PM |
Hi!
Will this work on a type 9, 4 speed gearbox from a 1970 Ford escort GT?
Best Regards
Sérgio
| posted on 6/1/08 at 10:57 PM |
quote: Originally posted by minidoido
Hi!
No, because it isn't a Type9 if it's a 4 speed. The 4 speeds have a different arrangement to retain the gear lever (large threaded
retainer) rather than the simple bolted on plate that the Type 9 uses.
NS Dev
| posted on 7/1/08 at 12:52 PM |
I made one not dissimilar to David Jenkin's item, after looking at the westfield et al ones and deciding that they were far from great!
Having two "selector forks" in the mechanism effectively doubles the play in the system.
Mine uses the original bellcrank and the original fork from the original gearlever, so no play at all.
Combined with a raised shifter bearing turret and a large spherical bearing (from the end of an old hydraulic cylinder) the gearshift is super precise
and incredibly positive. With a 10" long gearlever it gives about 1.5" of crossgate movement at the knob and about 2" fore and aft
at the knob.
Only problem now is the synchro is not as fast as I am!
minidoido
| posted on 9/1/08 at 10:22 AM |
Does anyone ever made an extension for the 4 speed gear box?
Ideas please...
