Aaron
posted on 13/7/03 at 01:30 PM |
Engine mounting bracket screws?
Just a quickie guys. What size screws were used to attach the mounting bracket to the block on the standard 711M crossflows fitted to Escorts?
It's just that I've got a feeling my block has been re-drilled and tapped for some reason!?!
Cheers, Aaron.
theconrodkid
posted on 13/7/03 at 01:36 PM |
10x1.5 i think,should be same as bell housing size
who cares who wins
pass the pork pies
Aaron
posted on 13/7/03 at 02:57 PM |
Cheers chaps, I suppose I best go have a look.
Aaron.
kingr
posted on 13/7/03 at 07:04 PM |
I've got a Xflow with a 771M block and even that doesn't have metric bolts.
Kingr
posted on 14/7/03 at 07:57 AM |
They are UNC, and they have funny heads - the head has a 'washer' moulded in under the hex bit, and the underside of that has sawtooth
serrations.
The effect is that they are easy to do up, but quite hard to undo - bit tough on the steel of the mounts though!
You are unlikely to get the real ones any more, even in a scrappy, but you should use some form of shake-proof washer under a conventional bolt.
