joscorstjens
posted on 12/3/07 at 11:09 PM |
oil shower
Hi, I just got an oil shower from my pinto engine. The engine was running for the first time and when it was heating up, it suddenly started p*ssing
out oil, like a shower. By the time I shut down the engine, there was a big puddle of oil on the floor. (Still enough oil in the engine though, so no
seizure risks.) As far as I can tell the leak must come from the oil filter joint which doesn't appear to be fully 'flat'; possibly
I overtightened the filter. Surprising how high the oil pressure can be when you get it all over you(on the oil pressure meter it only reached 35
psi)! Could some internal channel be blocked? Any other reason for such a pressure build up? Is there any other possible cause I should look for?
The whole motor compartment is a terrible mess, so I want to be sure that this will not happen again.
tia for your help
jos
blueshift
| posted on 12/3/07 at 11:27 PM |
do you have a crankcase breather? is it blanked off?
thomas4age
| posted on 12/3/07 at 11:37 PM |
just thinking out loud here.
Have you got a remote filter set-up or a sandwhich plate to an oil cooler?
somebody in the toyota corner once put it on the wrong way and installed door type filter, he had presure buildup and the filter came off, problem was
that the filter prevented oil to enter the engine, and he ruined it before the first meter was drivven....
otherwise it's probably crankcase ventilation as suggested
grtz Thomas
If Lucas made guns, Wars wouldn't start either.
nitram38
| posted on 13/3/07 at 05:57 AM |
Could be just the oil sealing ring on the filter?
Make sure that you take this off the filter, smear both sides of the ring with oil then refit. Might help?
| posted on 13/3/07 at 07:35 AM |
Sounds like the filter is cross threaded
russbost
| posted on 13/3/07 at 08:07 AM |
If the oil pressure relief valve has stuck shut it would do just what you've described, but in which case I would expect to see at least 70 psi,
possibly much higher. My suspiscion would be simply that the filter has been overtightened (they don't need to be all that tight, about 3/4 of a
turn once the seal is in contact) & has squashed the seal out of the side.
Howlor
| posted on 13/3/07 at 08:24 AM |
Just another point I can think of, do you have the shortened sump? If so have you filled the oil to the book level? in which case it will be
overfilled.
| posted on 13/3/07 at 08:27 AM |
it is difficult to say without knowing all the detials or seeing.
is the fitler the corret one? is oil pump good and pressure relieve spring know to be good? if filter faulty?
I';d be very surprise if crankcase ventilation would cause that sort of pressure - and even if it was at fault, why wuoud it cause oil to come
out at the oil filter interface?
any chance the sealing ring popper out of its seat?
I know when I ws messing with my landrover (v8, removte oil filter, I notice that with the engine running, the oil filter was much harder to turn that
with it not - I can only guess that the oil pressure was forcing the filter on tighter) - you only need to do it up hand tight.
| posted on 13/3/07 at 11:16 AM |
Usually if the relief valve sticks at cold next start the outer can of filter will blow clean off like mortar shell leaving the screw on base. ---
This frightened the hell out one Commer/Dodge PB van owner I knew as on the these vans with old Rootes 1725cc engine the oil filter is directly aimed
at the drivers seat !
davie h
| posted on 13/3/07 at 12:01 PM |
i had a fiat brava that did the exact same thing ran ok for a few seconds and then sprayed oil everywhere from the filter. turned out to be the
pressure relief valve which was stuck in the oilpump housing this was causing the pressure to go sky high and was pushing the oil filter seal out the
side between the block and the filter
DarrenW
| posted on 13/3/07 at 12:06 PM |
I know of a BECer that experienced the filter unscrewing itself when on the road - not a pretty experience.
joscorstjens
| posted on 13/3/07 at 10:59 PM |
In the mean time I discovered that on the oil filter I had two seals stacked on top of each other. So, most likely, that will be the cause .... I
hope. Thanks for the responses.
nitram38
| posted on 13/3/07 at 11:04 PM |
Ahem.................
| posted on 14/3/07 at 09:05 AM |
no doubt about it! easu to fix too
... how on earth did you manage that? did the old ring stick to the housing and you did not notice????!??!?!?!?!?!?!?!?!?!
joscorstjens
| posted on 14/3/07 at 11:49 PM |
very yes indeed
