blakep82
posted on 13/3/07 at 09:52 PM |
do you think an essex dizzy will replace this?
OK, so may be a trick question, but i want to know if anyone's thinking what i'm thinking, so, what do you think it is, and once i get the
answer i want, i'll tell you what i think, and you tell me if it'll work. simple
distributor
[Edited on 13/3/07 by blakep82]
________________________
ned
posted on 13/3/07 at 09:55 PM |
I'm thinking 4 3/4 inches isn't long enough, what are you thinking?
beware, I've got yellow skin
blakep82
posted on 13/3/07 at 09:59 PM |
i'm thinking its not the size, its what you do with it, at least thats my excuse
er, yeah, anyway, its from a ford, i'll give you that much
stevec
posted on 13/3/07 at 10:03 PM |
Henry V6?
blakep82
posted on 13/3/07 at 10:05 PM |
it a ford V6, yes, but i'm looking for a particular one... not easy i know...
stevec
posted on 13/3/07 at 10:11 PM |
Essex engine Motorcraft type dizzy?
[Edited on 13/3/07 by stevec]
blakep82
posted on 13/3/07 at 10:15 PM |
quote: Originally posted by stevec
Essex ?
you get the prize! Its actually not from an essex at all, but was hoping for that answer!
here's an essex [img][/img]
and a cologne
ford dist 2
the truth is, the first one came from an american Vulcan V6 from a ford aerostar (also fitted to rangers) but they are all EFI, i want a carb, so
looking for a strong contender for replacement distributor.
what do you think are the chances?
stevec
posted on 13/3/07 at 10:17 PM |
sorry added a bit while you were replying.
Steve.
blakep82
just realise, cologne also seems to have the gears the wrong way around on the bottom...
Mr G
posted on 13/3/07 at 10:20 PM |
2.8 mfi's had a geared drive, whereas the 2.9 efi's used a chain so shaft rotation is in the opposite direction.
posted on 13/3/07 at 10:22 PM |
Ditch the clockwork and fit a Megajolt system? The Ford EDIS module is available for V6's, all you need to do is attach a trigger wheel, VR
sensor and coil pack to it. You get to fit a carb, and benefit from optimisied ignition timing.
[Edited on 13/3/07 by MikeRJ]
blakep82
posted on 13/3/07 at 10:29 PM |
I've seen people talking about megajolt on here, but never looked to see what its about
where do i get it? do i have to build it up myself? where do i find more info? I'm sure its been answered and asked (not in that order) many
times, so please point me in the right direction
blakep82
posted on 13/3/07 at 11:01 PM |
http://www.trigger-wheels.com sell a kit containing used EDIS-6 module, coil pack, sensor and connecting wiring for £80, trigger wheels are another
£20.
I understand the engine should be able to run alone on this but without much spark control (advance etc) but will do to get it running, and i could
add the megajolt at the end of the car build. just want the engine running for now basically...
[Edited on 14/3/07 by blakep82]
posted on 14/3/07 at 07:32 AM |
^^^^ I've been asking about this stuff, and you're right, froinm whgat I have learnt, that will get engine running at fixed advance, 10
degree.
The Megajolt takes sensor inputs and does magic to provide more advance as required.
blakep82
posted on 14/3/07 at 07:45 PM |
does anyone know of a good uk supplier for both the ford V6 EDIS/crank wheel/sensor/etc set up, and also megajolt?
cng1
posted on 15/3/07 at 08:13 AM |
Drop a line to trigger-wheels.com as they're now reselling megajolts.
Chris
blakep82
posted on 15/3/07 at 08:15 AM |
Chris
wonder if they might do some kind of deal?
cng1
posted on 15/3/07 at 10:10 AM |
Could well be
