Steve Lovelock
| posted on 17/3/07 at 08:36 AM |
Which clutch cable for Type 9 & Luego
I am running a Type 9 gearbox in a Velocity using the standard floor mounted pedal box. What clutch cable are people using for this set up?
NeilP
| posted on 17/3/07 at 09:30 AM |
Type 9 in a Viento with floor mounted and just using the bog standard Sierra cable (you'll need to make up a 'thingy' of sorts to
secure it to the pedal)...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
flak monkey
| posted on 17/3/07 at 09:33 AM |
A capri clutch cable should fit. Not entirly sure what the pedal is like in a Luego, but the capri cable has a nipple on one end to attach to the
release arm, and a 6mm eye on the other end for a bolt. Makes fitting nice and easy.
Sera
http://www.motosera.com
mat.price
posted on 17/3/07 at 12:15 PM |
i uesd an escort mk2
the part number is QCC1061 from burton power
hope that helps
| posted on 17/3/07 at 01:21 PM |
Easier to use a Capri or Mk2 escort cable . Sierra one with the auto adjustor is too much messing around and the auto adjustors are not always
reliable
