darrenga
| posted on 20/3/07 at 01:56 PM |
zx 600 carbs
are these carbs ok to use on a pinto
| posted on 20/3/07 at 02:01 PM |
Should be OK. what size is the inlet diameter there? 36-38mm should be fine. Webers would have a smaller choke.
40~42mm would be much better, using zzr1100 on my zetec.
darrenga
| posted on 20/3/07 at 02:03 PM |
pic of other side
Mr Whippy
| posted on 20/3/07 at 02:12 PM |
I wonder how easy it would be to get different jets to suit the engine size?
| posted on 20/3/07 at 05:08 PM |
As easy as buying a set of indexed drill bits
jacko
| posted on 20/3/07 at 05:18 PM |
Hi I have zx9r carbs fitted to a 20l pinto there 41mm chokes and the jets where drilled out to 1.7 mm
try doing a serch about this subject
Jacko
