Author: Subject: SWMBO's Rover Metro 114 GTa
mike smith1
posted on 21/3/07 at 02:16 PM Reply With Quote
As above SWMBO's Rover Metro 114 GTa Pile of S**t has gone wrong again, sunday it would not start as if the starter motor has stuck, rock it in gear, tap starter with hammer hey presto it started,
Last nite at 6pm same again in works carpark, tried to bump it, nothing didnt even turn the engine , so a mate of mine has looked and he tried it today and it started to turn eventually and fired up he seems to think its hydraulicing, we rebuilt the engine after she managed to snap a valve spring end of last year. Used a pucker head gasket, i'm not aware of it gettin over hot. does anyone have any experience of this or is it just the good old k series again??
Mike
[Edited on 21/3/07 by mike smith1]
posted on 21/3/07 at 02:19 PM Reply With Quote
Been wondering for a while now... what does SWMBO stand for?
UncleFista
posted on 21/3/07 at 02:25 PM Reply With Quote
She
Who
Must
Be
Obeyed
Tony Bond / UncleFista
Mr Whippy
posted on 21/3/07 at 02:50 PM Reply With Quote
clearly not married...
posted on 21/3/07 at 03:34 PM Reply With Quote
yeah, married but I just don't take any notice....
Spoke to her a few weeks ago,
"What do you think of me new car love?" pointing at the MNR.
"F*cking waste of money " she says, walking out of the garage..
So, if I say SWITNNO, do you know what I mean???
[Edited on 21/3/07 by coozer]
posted on 21/3/07 at 03:39 PM Reply With Quote
she's right you know!!! all t hat money can be better spent on make up, shoes and hand bags.
andyps
posted on 21/3/07 at 04:50 PM Reply With Quote
Not sure quite what this means, but from what you have said it sounds like a starter motor problem which would be very unlikely to be related to the possible problems of overheating which some K series engines suffer from. Possibly just the ring gear on the starter motor sticking, or the motor itself or the solenoid or maybe the wire connecting the two.
omega 24 v6
posted on 21/3/07 at 05:27 PM Reply With Quote
If you think it's hydraulicing, then after a decent run let it sit for an hour, then remove the plugs and turn it over on the starter. if you get a shower of water you've got a problem.
posted on 21/3/07 at 05:34 PM Reply With Quote
Sounds like your starter is nadgered mate. Brushes are the most likely culprit.
posted on 21/3/07 at 06:51 PM Reply With Quote
Did you fit a new inlet manifold gasket when you did the head gasket?? They leak water into the inlet port/cylinder which will cause them to have a hydraulic lock AND they bend con rods big time.!! Check the inlet gasket!!
posted on 21/3/07 at 08:01 PM Reply With Quote
Most likely cause is a starter motor fault could be something very simple like the fork is sticking due to crap build up, just take the starter off an clean it.
owelly
posted on 21/3/07 at 11:12 PM Reply With Quote
I've been playing with the very same starter motor on a 414. On the one I took off the car and the two from scrappies, the braided cable from the solenoid to the inside of the starter had work hardened and snapped. Trying to resolder them ended up melting the gubbings inside the windings.
http://www.ppcmag.co.uk
tks
posted on 21/3/07 at 11:30 PM Reply With Quote
muahh its that called love??
if she would say that to me i would have a answer for her....
Tks
[Edited on 21/3/07 by tks]
mike smith1
posted on 21/3/07 at 11:45 PM Reply With Quote
Thanks for the replies guys,
answers to a few of them
Yes fitted new inlet manifold gasket but will check it again.
Had all the plugs out no evidence of water but wasn't stood very long so will give that another go.
Another pointer that its the head gasket is that when the expansion bottle top is removed with the engine running the water overflows.
Steaming through exhaust slightly as well, looks like its gonna be head off at weekend!
Thanks again
Mike
