bodger
| posted on 22/3/07 at 10:10 PM |
Fuel senders & tank foam
What sort of fuel sender do you need if you want to put foam blocks in your tank?
emsfactory
| posted on 22/3/07 at 10:25 PM |
Is it not one of those pipe things with the float in it? i cant remember the name.
Macbeast
| posted on 22/3/07 at 10:27 PM |
A sight glass ?
RazMan
| posted on 22/3/07 at 11:12 PM |
A Landrover one has pump and sender in a cylinder which should stay out of the way of any tank foam.
Raz
jdgar
| posted on 23/3/07 at 03:58 AM |
This is also a question I have, because my tank also has foam. I haven't yet figured how to hook up a sender. I don't fancy a stick-and
that would probably mess up the foam anyway.
"If it 'ah one ting, is a nex'.
Mike S
| posted on 23/3/07 at 07:53 AM |
My tank is foam filled. Used a VDO Dip Tube sender.
Available in various lengths to accomodated different tanks. Also different resistance ranges to match the gauge.
Mike
There are more horses' asses in this world than there are horses
bimbleuk
| posted on 23/3/07 at 10:43 AM |
As Mike says!
Saves me typing
