DarrenW
| posted on 23/3/07 at 08:43 PM |
Coil packs + MJLJ timing lights
Im having a moment!!
Ive got a xetec coil pack. It is marked up 1 2 3 4.
Im only used to dizzys. Firing order is 1 3 4 2. On Dizzy first point goes to 1, next point to 3 then 4 then 2.
Does the same apply to coil packs. ie 1 to 1, 2 to 3, 3 to 4, 4 to 2???
[Edited on 23/3/07 by DarrenW]
jacko
| posted on 23/3/07 at 08:49 PM |
Hi Darren
stevebubs
| posted on 23/3/07 at 08:55 PM |
Firing order for xflow is same as zetec so connect cylinder 1 to 1, cylinder 2 to 2 etc etc
DarrenW
| posted on 23/3/07 at 08:58 PM |
Good answer    (Jacko i meant)
DarrenW
| posted on 23/3/07 at 09:00 PM |
Is xflow the same as pinto?
So basically the coil packs are marked up in terms of what cylinder they need to be connected to rather than just sequentially / in order???
DarrenW
| posted on 23/3/07 at 09:12 PM |
Connected 1-1, 2-2 etc and it rens sweet.
Is it normal for a snap on advance timing light to read double revs and double advance with EDIS etc???
UncleFista
| posted on 23/3/07 at 09:23 PM |
Yes, 'cos it runs wasted spark
Tony Bond / UncleFista
jacko
| posted on 23/3/07 at 10:09 PM |
Darren keep up the good work you will get there in the end
Graham
DarrenW
| posted on 23/3/07 at 10:24 PM |
Im just about there. Car has been running very well. Any issues ive had have not been the MJLJ. Ive programmed Steve's map in and looking
forward to a test drive sometime. I just need to instal it all better first and strip out the std dizzy set up.
TBH im quite enjoying myself. Spent most of tonight just playing with it. Maybe i should have completed the install!!
Why dont you have a go - go on, you know you want to
flak monkey
| posted on 23/3/07 at 10:30 PM |
Well done Darren, wondered how late you would be up annoying the neighbours
Sounds like you are getting there, good work!
Sera
http://www.motosera.com
DarrenW
| posted on 23/3/07 at 10:51 PM |
i didnt start till late, i had to dry off first!!!
The backfires were concerning at first until i sussed out the coil pack wiring. once leads were changed around it fired straight up and ran nicely.
It has just dawned on me that whilst trying it all out, there is nothing to stop me mounting the TPS in the dash and say set up 5 different 2D maps
which i can simply try out whilst driving around. Basically use the TPS as a switch to change maps on the fly.
TangoMan
| posted on 24/3/07 at 08:58 AM |
Good bit of improvisation Darren but you would be better of fitting the TPS properly as you will only see the real benefit of MJ once you have a 3D
map.
Good to hear you are getting there though. See, it's not as hard as the doubters would have you believe.
As others may have the same problem, how did you sort the comms problem out?
Thanks for the nod on Teeside
Summer's here!!!!
DarrenW
| posted on 24/3/07 at 08:17 PM |
Another random thought ive had - if the system is wasted spark does that mean the sparkplugs do twice the work as normal? Should i consider a change
of plugs as a result - what would you recommend.
Good point Steve ref TPS twiddling. Ill get the install put right (ie temp to perm) and see how i get on. Need to get out on the road to test it out.
jacko
| posted on 24/3/07 at 08:37 PM |
Looking good Darren it will be worth it in the end
i am not a doubter i dont have a lap top so the dizzy way was easier for me
when you fit the bike carbs on they have tps so it will be good for you to use that.
Graham
DarrenW
| posted on 24/3/07 at 08:46 PM |
Unfortunately Graham my bike carbs dont have TPS and the throttle spindles dont extend out of the castings so a bit tricky to fit my pre-wired TPS. I
managed to build a car so wont let something like that stop me!
Carbs are ZZR1100. Im sure someone will have done it. I did think of fitting sensor to pedals but being floor mounted access is not that good.
