speedyxjs
| posted on 24/3/07 at 05:15 PM |
What does your engine weigh?
Also, does anyone know what my 2.9 aj6 jag engine weighs and what a 4.0 supercharger aj16 jag engine weighs?
Johnmor
| posted on 24/3/07 at 05:19 PM |
Alfa v6
Alfa 136 kgs with no Ex manifolds and alternator etc.
aj6 is a craking unit and all alloy,
someone has put it in a Viento.
12a RX-7
| posted on 24/3/07 at 06:01 PM |
Mazda 13B Rotary - 83Kg no turbo's no inlet etc.
[Edited on 24/3/07 by 12a RX-7]
mark chandler
| posted on 24/3/07 at 06:05 PM |
v12 is 309kg undressed so its going to be a minimum of 200kg !
2.9 had a v12 cylinder head, not very good, the 3.6 and 4.0l DOHC's were much better, I had a 4.0l XJS a few years ago, went really well, faster
than the v12 it replaced as it was a rare factory manual. Should never of sold it
Regards Mark
ecosse
The only figures I ever found for the aj16 engine were about 220Kg, and that was reputedly bare i.e. without injection, chargers, alternator etc etc
, not sure about aj6 or the 2.9 but I would imagine the 2.9 would be slightly lighter being a single cam as against a twin cam (is it still a ally
head on the 2.9?)
So a serious lump of an engine, but when you see (and lift) the crank from one you start to understand why
It was apparently designed around the possiblilty of a diesel variant being introduced, so the bottom end was over engineered just in case (which will
be why they run forever when looked after).
Alex
smart51
| posted on 24/3/07 at 06:14 PM |
1998 R1 60kg. Fully assembled including clutch and gearbox, plus all ancilliaries but no carbs.
jacko
| posted on 24/3/07 at 06:22 PM |
Pinto 1 ton is that right Hellfire [ phil ]
Graham
Mansfield
| posted on 24/3/07 at 06:34 PM |
1.6 CVH - between a hernia and a bad back!
jos
| posted on 24/3/07 at 07:39 PM |
another with a 1 ton pinto here
Simon
| posted on 24/3/07 at 08:05 PM |
Rover V8, stainless manifolds, stainless system, pair turbos, paired intercoolers, injection manifold.......
Er, quite a lot, I suspect
Simon
lsdweb
| posted on 24/3/07 at 08:31 PM |
Not sure - somewhere around 70kg? The whole car's bang on 350kg..........
Julian B
| posted on 24/3/07 at 08:35 PM |
I think the rover v8 is a little less than 150 KG's
I think!
| posted on 24/3/07 at 08:45 PM |
Graham
Sounds a bit light to me Graham. Thats not including the gearbox, ancillaries and fluid though, is it?......
Phil
jacko
| posted on 24/3/07 at 08:59 PM |
O i forgot about the box etc add 1/2 a ton for them
see you it may Graham
craig1410
| posted on 24/3/07 at 09:25 PM |
Rover V8 - Around 144Kg's
robertst
| posted on 24/3/07 at 09:47 PM |
its not THAT heavy!! ok 170kg for a four pot is a lot, but its no big deal....
Chippy
| posted on 24/3/07 at 10:36 PM |
2.9i V6, not sure but definately need an engine hoist to lift it, supposedly the heaviest boat anchor around, (but maybe the quickest  ) Ray
t.j.
| posted on 25/3/07 at 06:03 AM |
Oh Oh, here we go again......
Come on in, you BEC drivers.....
[Edited on 25/3/07 by t.j.]
MikeR
| posted on 25/3/07 at 07:35 AM |
PPC did an engine swap article a couple of months ago. I'd love to quote from it now but i'm away from home. maybe someone else can help
out.
PaulBuz
| posted on 25/3/07 at 11:14 AM |
My Sierra DOHC is 135kgs dry.
Paul
martyn_16v
| posted on 25/3/07 at 12:14 PM |
Mine feels like it'll compress into a black hole at the end of it's lifetime. It's certainly got it's own gravity, everything
in the garage seems to have clustered around it
mookaloid
| posted on 25/3/07 at 08:27 PM |
Graham
You forgot to take off a few grammes for tthe lightened flywheel Graham
jacko
| posted on 25/3/07 at 08:37 PM |
 Hi Mark [Mookaloid } how are you
Graham
goodall
| posted on 25/3/07 at 08:49 PM |
http://www.gomog.com/allmorgan/engineweights.html
http://www.team.net/sol/tech/engine.html
two websites with information on engine weights iv had them both bookmarked for a good while now, he first one is just an extended version of the
second one i think
NS Dev
| posted on 26/3/07 at 07:36 AM |
depends which car!!
in the 7, Vaux XE, 115kg ish
in the class 7 grasser, 58kg all up with ancills, manifolds etc................................but there are two of them so 116kg, but then
that's not bad for 300hp!
