smuty
posted on 24/3/07 at 06:36 PM |
polly bush grease
Hi All,
Im about to put bushes in to the wishbones do i need to use grease, if i do what type? and where do i apply? between bush and wishbone or between
crush tube and bush or both. Cheers.
bodger
posted on 24/3/07 at 06:43 PM |
Use some moly grease between crush tube & bush.
posted on 24/3/07 at 07:11 PM |
Used Rubber grease on mine , lot less messy than moly grease .
wilkingj
posted on 24/3/07 at 08:10 PM |
Silicone Rubber Grease from Radio Spares on mine.
Best Regards
Geoff
http://www.v8viento.co.uk
Chippy
posted on 24/3/07 at 10:54 PM |
You can use any grease that you happen to have, Poly bushes are not affected by oil or grease. Gave mine a good lathering in the stuff, makes it
easier to get them together, then washed of the excess with parrafin. Ray
