lough
| posted on 24/3/07 at 07:52 PM |
Zetc Sump
Daft question, can you fit a fiesta sump to a 1.8 Zetec silver top , as they look quite shallow?
Chr!S
| posted on 24/3/07 at 09:14 PM |
Yes you can. I assume you mean the MK3 fiesta Zetec sump
I built a 2.0 fiesta mk3 a while back, recycled the 1.6 sump and had no problems with oil supply whatsoever.
You need to change the oil pick-up pipe over too otherwise it wont fit.
| posted on 24/3/07 at 09:53 PM |
Interesting, how much smaller is the sump? Mine is 170mm from the gasket line at the bottom of the block.
