les
| posted on 28/3/07 at 11:40 PM |
fuel sender
hi guys,
bit of advice needed- think i may have made an error--
where the fuel sender attaches into the fuel tank, i have used 5mm rivets through the holes in the flange- all seems very solid- after reading an old
post wondering if i was supposed to use screws?
any thoughts on if this is a problem?
cheers
les
stevebubs
| posted on 29/3/07 at 12:55 AM |
If you intend to take it out at somepoint then be aware that drilling a tank always has a risk associated with it. Using screws removes this risk.
Other than that, just make sure it's sealed properly.
Rudy
| posted on 29/3/07 at 06:13 AM |
I used rivnut, seems very weel.
Sorry about my English
les
| posted on 29/3/07 at 07:53 AM |
hi,
thanks for the replies,
I did drill the holes and then used rivets- used a magnet to get all the bits out of the tank-
i saw a post which recommended screws be used, but as you say drilling out the rivets now, could cause more problems than its worth.
thanks
les
