zetec
| posted on 29/3/07 at 11:17 PM |
Cam advice
Now I've started porting a spare head for my Zetec I've also started on the search for a new hot(ish) cam.
Now I know I should leave the head work to the pros but I'm having a bash, and I think I'm pretty damn good .
The tricky bit is picking who to get my cams from. I started off with Piper, then Catcams came along followed by Newland, and Kent Dunnel toooo
pricy.
Any advice wood be good.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
Fatgadget
| posted on 30/3/07 at 12:06 AM |
The rule of thumb of picking the ideal cam. Choose a lower profile than the one you really want! I once had L1 cams in my BDA when I should of had
L2s!
| posted on 30/3/07 at 08:59 AM |
let's see photos of what you are doing/done.
zetec
| posted on 31/3/07 at 03:38 AM |
Pics so far, finish looks rougher than it is, will just smooth a little more and will be done. Exhaust ports seem to have more scope for opening
out.
zetec
| posted on 31/3/07 at 03:39 AM |
How they started..
zetec
| posted on 31/3/07 at 03:42 AM |
Exhaust port open out..
TangoMan
| posted on 1/4/07 at 08:00 AM |
Make sure you clean up the transition from throats to valve seats to chambers as this makes a surprising difference to flow at low openings.
Summer's here!!!!
