Catpuss
| posted on 31/3/07 at 12:13 PM |
Type 9 clutch release arm removal
OK, How the chuff does the clutch release arm come off the type 9 box>
According to the book of lies its a couple of push springs behind the arm and the MT75 box has a circlip.
Well I can't find any springs and I'm sure I can feel a couple of holes for a circlip. Anyone had experience of this before? I assume its
a spreading open circlip not a closing up one?
omega 24 v6
| posted on 31/3/07 at 01:14 PM |
You wont be able to remove it unless you take off the gearbox and the release bearing first. Then pull it towards the cable end opening in the
bellhousing and it should come off. The springs are actually two fingers underneath the clutch release arm (hope this makes sense) with humps on them
that locate on the fulcrum peg.
Catpuss
| posted on 31/3/07 at 02:26 PM |
Thanks.
What I'm trying to do it get the bell housing off. I can't get the bearing on the shaft off. There are two bolts that are behind the
release arm to separate the bell housing from the gear box and I can't get to the buggers.
I've felt around the back of the release arm for the humps and fingers (as per the picture in the haynes book) but can't feel the right
shape there. I can feel though the shape of a circlip (i.e. the two small holes on the fingers).
Most odd it is.
Catpuss
| posted on 31/3/07 at 03:40 PM |
OK. Started again. The clips are behind the back ring and its just a little tang. I guess I was looking for the wrong thing. A quick press behind the
lower one and the upper one and it popped off like a greased pig (which is what is was really).
Bell housing now off and all is peachy.
martyn_16v
| posted on 31/3/07 at 04:59 PM |
I gave up trying to undo the clips behind the release arm when I had to get mine off, instead I tapped the release arm pivot pin out of the
bellhousing with a small punch.
robertst
| posted on 31/3/07 at 08:34 PM |
what a coincidence, i'm also working on the gearbox and had this same issue yeasterday.
i wouldnt reccommend hammering the pivot pin out as its just not meant to be fiddled with.
i simply used a screwdriver and putting it through the opening on the bell housing where the clutch cable goes i hammered the lock tabs out.
bear in mind you cant reuse them and it is easier to get a new bearing as it comes with these lock tabs.
btw: the haynes book doesnt cover it in detail at all, but what you're really supposed to do is get a small pointy thing (book says an allen
key) to push the lock tabs out from the middle top and bottom part of the back of the bearing.
its a very cumbersome job...
[Edited on 31/3/07 by robertst]
Tom
