Author: Subject: oil pressure sender / leak
les
posted on 2/4/07 at 09:30 PM Reply With Quote
hi guys,
engine all up and running- but got an oil leak from the oil pressure sender (zetec)
i could refit the old sensor, and move the sender to a sandwich plate which i have bewteen the oil filter and engine,
anyone know if it a good place to read oil pressure?
les
DIY Si
posted on 2/4/07 at 09:35 PM Reply With Quote
Do you have an electrical sender or mechanical? If mechanical a bit of ptfe/plumbers tape may sort it out. If electrical, is the sender fully done up, or of the correct thread?
Sun Tzu, The Art of War
posted on 2/4/07 at 09:41 PM Reply With Quote
Yup. PTFE tape rules... Had an annoying leak from the oil pressure sender (though I'm also being naughty and using a T-piece to attach the low pressure light switch....)...
PTFE tape sorted it out.... I really should attach a flexi hose before the block cracks....
les
posted on 2/4/07 at 09:48 PM Reply With Quote
hi,
thanks for the replies, i have a mechanical racetech sender, in an adapter- again for the oil light sender!
for oil temp, ive got a mechanical racetech sender in the sandwich plate- which has couple of extra connections i could use?
will try the tape solution!
les
