myles
posted on 5/4/07 at 07:57 AM |
2l zetec alterations!!!
hi all,
running or hoping to run a 2l silvertop zetec, have changed the water pump with no problems and now putting the fan belt back on although i am having
some problems with that! i just cant get it on! feels like the alternator is just out of reach, does anyone have a pic of what it should look like?
do i need to change the alternator?
sorry if its basic stuff but we were all learners at some point!
Ivan
| posted on 5/4/07 at 08:31 AM |
Asking the obvious - have you slackened off the alternator adjustment?
myles
| posted on 5/4/07 at 08:34 AM |
the obvious may be the answer!
i take it that is just the bolt on the alternator wheel released?
myles
| posted on 5/4/07 at 08:46 AM |
actually im not sure that is going to work, the alternator is not going anywhere it is bolted down hard but there is a tensioner below it but even
then there is not quite enough slac, plus it is a ribbed belt and the tensioner wheel is suposed to be smooth!
DarrenW
| posted on 5/4/07 at 10:16 AM |
Most alternators have a pivot bolt at one end and an adjuster mech at the other. On mine (Pinto) i have to loosen the pivot bolt, then the adjuster.
Slide the alternator towards engine, belt on then adjust the slack first and nip up the adjuster. Then nip up the pivot bolt.
Some cars have a slotted adjuster, others have a screw type. Either way you hove to slacken off to release tension fully. Belt may still be a touch
tight to get over but once on you will see it is slack.
For tension - on the longest run with finger and thumb you should be able to just turn it 90deg. That is the basic rule without getting a tension
gauge out. Works for me.
zetec
| posted on 5/4/07 at 01:47 PM |
I thought the standard setup used a spring loaded pulley...
Ditch the standard setup and make or buy a new fitting to mount the alternator. You can then ditch all the other pulleys used when the engine has PAS
and A/C. Most fit an alternator under the inlet manifold with a belt to a grooved water pump pulley and bottom crank pulley only. This is far easier
and allows you to tension the belt using a traditional arm/bolt arrangement on the alternator.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
stevebubs
| posted on 5/4/07 at 04:20 PM |
I think I've a silvertop tensioner on my install. Basically get a big spanner on the tensioner and rotate it clockwise. The tensioner should
then move and allow you to slide the ribbed belt (which you've already put over the water pump and tensioner) over the alternator.
HTH
Stephen
big_wasa
| posted on 5/4/07 at 04:51 PM |
on the silver top most ditch the mondeo bracket and tensioner.
Not a mondeo alternator but you get the idea.
[Edited on 5/4/07 by big_wasa]
big_wasa
| posted on 5/4/07 at 04:57 PM |
And this set up I made my self from a renault 5 alternator
big_wasa
| posted on 5/4/07 at 04:59 PM |
And this set up I made from a sierra dohc alternator
big_wasa
| posted on 5/4/07 at 05:02 PM |
To add you will also need to change the pulley to one from an escort aswell.. Ie ribed and not smooth
TangoMan
| posted on 5/4/07 at 06:56 PM |
My setup is very similar to that shown by Big Wasa.
If you can get hold of an alternator of a DOHC or 1.8CVH Sierra it already has the correct pulley. They are available new off ebay (that's where
mine came from) for a reasonable price.
Summer's here!!!!
