turbodisplay
| posted on 9/4/07 at 08:32 AM |
Skyline turbo
I have a skyline turbo with a six bolt dump flange (output of turbine).
Anyone know where i can got a flange from, I managed to get one from ebay america, got the flange ground flat after welding and the engineer lost
it.
Can`t get the flange anymore from that person on ebay.
Darren
AlphaX
| posted on 9/4/07 at 09:24 AM |
make one on paper and have it laser cut. This enables you to make to your specs (thickness, material and shape).
turbodisplay
| posted on 9/4/07 at 10:39 AM |
I managed to do a cad drawing, but it was very complex. Main problem i have is that it is not an autocad format.
Need to convert its format otherwise the laser cutters will have to manually enter the data.
AlphaX
| posted on 9/4/07 at 10:53 AM |
send it through and I'll see what I can do for you with the file.
you can email it to info@alphax-kitcars.com
turbodisplay
| posted on 9/4/07 at 10:58 AM |
Cheers its a turbocad .tcw file, is that any good?
Darren
violentblue
| posted on 9/4/07 at 02:43 PM |
tubocad should be able to export as a .dxf wich is standard interchange between different cad programs
a few pics of my other projects
Jasper
| posted on 9/4/07 at 03:20 PM |
Do you need a complete downpipe or just a flange piece? I got the flange piece from the bottom of the downpipe into the rest of the exhaust laser cut
- just made a template up.
Have you been on the Skyline forum? They're bound to know.....
turbodisplay
| posted on 9/4/07 at 04:28 PM |
Just the flange, going to weld it up to 63mm pipe.
Re turbocad, it is a free version, which will not export, does everything else.
Darren
[Edited on 9/4/07 by turbodisplay]
