iiyama
| posted on 9/4/07 at 10:57 AM |
Wheel studs
Trying to put in some new studs on Sierra hubs. Havent got a press so Ive heated the hub in the oven and cooled the studs in the freezer. Still having
trouble getting them fully home though. Can I do this with an impact wrench and a whel nut? Maybe place an old wheel on and pull against that? Or will
I just strip the thread?
Ta!
[Edited on 9/4/07 by iiyama]
If its broke, fix it. If it aint broke, take it apart and find out how it works!
bigrich
| posted on 9/4/07 at 11:06 AM |
use a couple of washers to act as a spacer to allow the stud to fully seat then pull them through with a wheel nut on backwards(taperside out) you can
use an impact gun if you want but i prefer to use a ratchet and socket to feel if its too tight etc
iiyama
| posted on 9/4/07 at 11:15 AM |
Sound! Thanks dude!
Mr Whippy
| posted on 9/4/07 at 11:17 AM |
you should be able to pull them though with a wheel nut itself, plenty of grease and some large washers to space it out. Usually an easy job and no
need for a press.
| posted on 9/4/07 at 11:26 AM |
As above you need a really thick spacer and a few well greased washers -- use a steel wheel nut but put on backwards so the flat side is against the
washers.
