Author: Subject: alloy pipe
iceman26
posted on 9/4/07 at 12:05 PM Reply With Quote
alloy pipe
will alloy pipe be ok for use in the colling system
if so what thickness of pipe should i use
thanks
nitram38
posted on 9/4/07 at 12:07 PM Reply With Quote
Yes, just make sure you use anti-freeze in your system to stop the pipe corroding
About 1mm will do.
[Edited on 9/4/2007 by nitram38]
Guinness
posted on 9/4/07 at 06:31 PM Reply With Quote
B&Q do a nice 6' long TV aerial pole in 25mm dia 1mm wall aluminium.
Comes in two styles, straight and a s-shaped one.
's what I used.
HTH
Mike
Simon
posted on 9/4/07 at 07:26 PM Reply With Quote
http://www.nfauto.co.uk/cut_tubes.htm
Simon
