HAL 1
| posted on 9/4/07 at 01:08 PM |
New Carb jets
Hi, I'm having a bit of trouble getting my new carb set up, I can get it to idle quite smooth but when i road test it starts to 'pink
' very badly under load, It's an automatic box so unless i hammer it everywhere it changes quite early, I've been in touch with the
dealer who tells me that it's set up at the factory as a direct replacement for the old carb, that was bust anyway and original ones were crap
so I'm told, but dont quote me,
the problem i have with the factory set up business is that all except one jet are different, I dont get it
would it be a good idea to start by setting up with original jet sizes and starting again ?
I've checked valve gaps, timing it everywhere to no avail, all vacuum pipes etc.
Dingz
| posted on 9/4/07 at 01:30 PM |
It is your ignition timing, it will be too advanced, not the jets. check it again and try backing it off a few degrees.
| posted on 9/4/07 at 02:30 PM |
Has the engine run up before- if so and the only thing that's changed is the carbs then it could be they're going very lean under load
leading to overheating and pinking....
I'd suspect something more likely though- like the timing.... Have you done anything else to it since the engine was last run ? could one of the
cams have slipped or something like that?
HAL 1
| posted on 9/4/07 at 05:00 PM |
wherever i have the ignition timing it still does the same thing, I'm taking it to my brothers mate who has a gas analyser to see if
there's anything he can do, my main worry was why are all the jets different ? the reason the carb was changed was that it was had electronic
controlled choke/idle which basically was f***ed and no-one can do anything with those apart from bin them, I'll try the timing again before i
go but i'm not holding out any hope, thanks for the replies guys
